Arlo Pro battery charging stats.
  • 2 Replies
  • 3898 Views
Streak2
Master Master
After two months I received the 15% left reminder email yesterday on one of my cameras.
It's the highest traffic one of the ones I have installed. Resolution is set to the highest level.
It's the first time I am charging thre battery in this camera.
This morning I pulled it down to recharge it and at the same time used some test equipment to get some stats.
Initial charge voltage was 9.43v
Initial charge current was 1.08A
Charge voltage when fully charged 9.37v
Current when fully charged 0.11A
Capacity 1486mA
Total charge time about 2 hours.
I will wait for the next camera's battery to go totally flat and then redo this exercise to test the capacity of the battery from empty.
Pretty happy with these results.
Sounds very good...
Similar results here with hi quality video, ran in spec use for 2 months and had 43% left.... recharged only due to moving it and didn't do it after placed in new location
Streak2
Master Master
I forgot to mention, one small quirk,
The camera was online most of time while it was charging but then suddenly went offline.
After charging was complete I opened and closed the battery door, the blue led gave its fast flash and then it re-connected no problem.
