  • 6 Replies
  • 2903 Views
buss66
i am trying to figure out to subscribe to the business plan, i think its called enterprise.
6 REPLIES 6
Use a computer browser to go to https://my.arlo.com and then click on the house icon at the top left. Click on My Arlo Account. Because I have a plan, I have to then click on Change Plan at the top right - you may only be presented with the plan options at this point if you have no current subscriptions. Scroll all the way to the bottom and click on Business Plans under the fine print section.
buss66
Ok, this doesn't seem to be working for me.  I scroll to the bottom and i don't see any fine print with business plans.
buss66
I was able to find it!  Thank you so much!
ShayneS
Hi @buss66
Thanks for the update, please let me know if you have any other questions.
Dolamite
What is the difference between the business plans and standard plan? Also, how much is it to add CVR to cameras on business plan?
ShayneS
Hi @Dolamite
Thanks for your inquiry regarding the service plans. At this time, there are not any major differences with our Curren Arlo Secure subscription vs a business plan. You can add the CVR subscription with any Arlo Secure plan provided by Arlo. The current pricing is for 14 days for $9.99 per month or 30 days for $19.99.
Hope that helps.
