Bugs are triggering our Arlo Pro on one camera
  • 4 Replies
  • 5535 Views
  • 3 Likes
lcjdot
Every 1-2 minutes or less, once the sun went down today, something, and I am guessing bugs are setting off one of our cameras.  Both are under the eaves.  The other camera is not experiencing this.
The battery will drain at this rate.  This is ridiculous.  We have replaced a camera and we cannot get this issue resolved without turning off the IR and this is the one camera where we don't want to do that.
Anyone else experiencing this?  I have already turned the sensitivity down to literally 3 out of 100.
Here is the shared link: https://arlo.netgear.com/hmsweb/users/library/share/link/8AFD6F24FFD726AD_201612
I don't think its the flying bugs so much as the spider and web on the camera ( left side ).... Spider webs DO make the camera trigger off a lot if not kept clean and thats why you see the bugs.
You can also adjust the sense level if need be
steve_t
Master Master
I have had crawling bugs and spider webs trigger my cameras too. Now I spray insect barrier all around them and the problem has been greatly reduced
SecureDaughter
Same! Nothing like a 3:30 am notification panic thinking someone is on your mother's porch and then greeted by a spider, 😡😥
SecureDaughter
