How do I deny access to someone to whom I had previously granted access? My roommate will move out, & I don't want him to have access to our cameras any more. Thanks!
Simply remove him from Grant Access.
5 REPLIES 5
Easy,open app tap the 3 vertical dots in upper right hand screen, tap settings, tap Grant Access, tap the name of the person you want to remove, go to the bottom of the screen and tap Delete Friend. You might have to tap save and your done.
as above ...and also maybe a wise idea to change your primary password just in case
Thank you! Your response was helpful!
Thank you! That's a good tip.
