Been trying to charge one of my 10 cameras without success. Tried removing battery and from hub.
  • 1702 Views
JD56
Hi all,
I’ve been trying for weeks to charge one of my 10 cameras without success.
I’ve tried the usual removing the battery leaving it standing, then inserting the charger without battery.
I’ve also remove it from the hub.
The sync button does nothing at all.
On first connect of the charger the blue light is static for 1 second and then goes off again the sync button does not respond.
Has anyone else been through this torture and can advise of a work around / solution please?
I go through this regularly with the other cameras but this one is very stubborn!
Many thanks
Jonathan
JessicaP
Hey JD56,
Try looking at this article to see if that helps you out: My Arlo Pro or Arlo Pro 2 camera battery isn’t charging; what do I do?
Otherwise, contact the Support Team so they can further investigate this issue. You will find several options for contacting support in the provided link.
JD56
Just tried to send e mail on line to support but doesn’t go through due to error?
Is there an e mail address for support please I can send this to?
Email has been sporadic and faulty for years. Use chat or phone.
