It sound then like a glitch.... it would require you to remove both cameras and bring them back as new to fix the ARMED mode
( settings/ remove device )
It sound like the MODE your using has been change or glitched ( btw, you can set up the cams for A to sense and B to record)
Check the rules in the mode , esp for the front camera
Many thanks TomMac the problem is resolved, as you said I had to remove the rear house camera and bring back as new and that fixed the problem. The rear house cam was picking up motion and triggering the front house cam (strange). The only thing I can think what happened was we were setting up a new tv (smart tv) with wireless and the tv is a wall hanger and the outside cam is almost behind the tv but on the outside of the house and I think while setting up the wireless tv it interfeared with the cam and confused it and that was about the same time I noticed the cam problem, I have the wireless turned off on the tv because we dont need it. Thanks again Tom.
