Have ARLO pro and live in Central Illinois, just set up system about 2 weeks ago and we have now hit cold weather ..6-20 degrees F... all batteries show between 80-95% except one... it went to 5% over night from 90+%.... recharged it and warmed it up and it was at 96% this morning and now it's showing offline prob from battery life.... I know cold affects the battery but this much so fast???
Try swapping a different battery in that camera and seeing if it does the same thing. To see if it's a camera issue, or battery issue.
All seem normal except one..... swapp as mentioned and see if the problem is the battery pack... If the second battery pack does the same, swap with another camera to eliminate all possiblities
I also need help about battery life. Have the unit in St. Paul, MN. Battery went from 100% to 13% in 50 days. Need a solar option or alternative. Pain to replace the battery when you have to climb up in this winter... any suggestions?
A battery that drops to 25% in 8 hours is an issue. Swap batteries between cameras to verify.
ab4968,
The battery could be draining due to the camera location (poor signal strength or interference). Temporarily relocate the camera close to the base station and test again to see if you get the same results.
