While charging my Arlo using the Arlo cable and adapter I see the “charging” icon, but after 30mins it still shows 12%. Does the % of battery adjust while it’s charging??
Update. So I restarted the app on my phone and now it’s showing the % of change. Problem solved. Yeah.
It normally does. Where are you seeing the 12%?
12% shows up right next to the battery icon with a lightning bolt in it to reflect its charging. I started to charge the battery at 12% but it’s not increasing after 30 mins. Not sure it’s charging or not.
