Battery Compatibility Pro 4th, 5th, & 6th Generation
  • 4 Replies
  • 3055 Views
weegok
Are the batteries the same dimensional size and power output for the Arlo Pro 4th, 5th, & 6th Gen?  I know Pro 4 & 5 are interchangeable, just curious about Pro 6th compatibility.
Best answers
  • ShayneS
    Hi @weegok
    Thanks for reaching out regarding this. I found some of the compatible devices after inquiring with the team. The following are: PRO5/4/3 Ultra 3/2.  I hope that helps out a bit. Let us know if you have any further questions.
  • jguerdat
    They're all the same as long as you don't try to mix in XL batteries, which are longer.
ShayneS
Hi @weegok
Just to be clear - all standard size Pro 3/4/5 and Ultra 1/2/3 batteries can be used in the Pro 6.
XL batteries cannot be used because there is no XL housing for the Pro 6 and Ultra 3.
weegok
Very helpful  Thank you @StephenB
