Can someone tell me how to fix this? See screenshot. A base station is showing up as a device under the main base station. Furthermore, it has a red circle on top of it (that circle got lost when I pdf'd the web page). Doesnt seem right and I can delete it. Only allowing me to change the name of it. Thats all
This is the Siren feature for the Arlo Pro base station. It allows you to rename the Siren so that if you have multiple base stations on the same account, you know which siren you're triggering.
My arlo pro has all of a sudden a red dot with sound waves in it is on my base station picture Im not sure what that is and how to get it off.
Same issue here, does anyone know what it means:
It shows as a device under my base station with my cameras
Select one:
- Base is transmitting
- Base is not transmitting
- Base alarm is working
- Base alarm is not working
- Base is radioactive
- USB is really really hot
- Arlo GI developers are mysterious and like red
- Arlo is watching you watching it
C'mon guys. Changing the GUI's on everything without any explanations of what's new (upfront user enhancements is not a "what's new") only leads people to vent frustrations about the product.
Oh....thanks for the info.
