My Arlo base station does not power on anymore. The problem is definitely with base station and not with the adapter. I tried different adapter from my other working base station and it still does not power on. Is it possible to repair and if not is replacement available please?
There really is no repair service for the older ( and newer ) bases....
Best recommendation is to pick up a newer base unit and reset up the system.
Since you were running the 3000 base, I would at least say go to the 4000 base unit as it will give you a bit more.
( usb recording and the 4000 has a build in siren which is loud )
