  • 1 Reply
  • 1605 Views
Heavylite
I have been using Arlo for at least five years now. I have a base station with three LED lights. I purchased a new base station I purchased a new base station that has one LED light on it to add to my old bay station, which had three LED lights on it. The new base station would not be discovered by the application and during the process of trying to get it, discovered by the new bait station I removed the old beast station from the system. Now I am unable to add the old base station back to the system. It is now not discoverable. The new base station remains undiscoverable as well. I need help in getting these things back to functioning.
DannyBearAgain
If you’re using the mobile app the mobile device needs to be connected to the local wifi network else the app will not find any devices.
Try using a pc web browser to my.arlo.com with the pc connected to the local router modem.
Going forward you don’t need to remove the old base when adding another base station.
