I would try and turn your Modem, router , and base unit all off.... bring them online in the same order one at a time , let each one finish rebooting before the next.
The fastest way to try to resolve this is to reset the system and start fresh. Remove all devices from Settings, My Devices. If desired, also use the reset button on the base until the LEDs flash amber. Use the Add Device button in the Devices tab to add the base and sync the cameras. Do you get a prompt to update firmware and did it occur properly?
Sorry for the long delay in response- i have been busy lately.
i have tried all these approaches and still no success.
it is really frustrating and so i jus left the cameras operating only when it detect movement (but cant initiate viewing/recording on my own)
i really feel bad as i am not enjoying the value of the purchase.
Open a case with support. There's no reason whatsoever that you have to put up with a partially functioning system.
