I already have arlo base station and i have bought a new one because i needed it for arlo pro. Now i have connected my new cameras to my new station and i want to have my old base station in my nearby house with the same internet router. But now my old base station cant be connected, the computer cant even find it and i dont know why. Can someone help me please?
mm1233 wrote:
Yes i have removed it but now i cant even see it, it doesnt appear
did you try and bring it back as a new base under ADD A DEVICE?
If you did, plug the base into power and ethernet, then do a reset... hold the reset for ten sec till the front leds flash.
Then bring in using add a device.
If you used REMOVE device on the base like you should have, it is a simple matter to bring it back as a NEW item
( otherwise if you sign into the account youshould still see it )
It will appear along with your other base.
Now it worked, thank you!
