We had a power outage 2 months ago and now the base station will not connect to my wifi! All lights are green, but asking for a password to connect. WiFI password will not work and it will not automatically connect like before!
There is no wifi that you can connect to with the Arlo base station. You plug it into your router and your cameras use their own separate wifi to talk to the base station.
The green lights suggests that your base station is working. The password request is more likely to be from the router that you plugged the Arlo base station into.
Just another user
@VernitaC wrote:
When I try to add the base station on the App it tells me to connect to my phone. When I go to settings and click on the base station that is showing as one of my networks, it will not connect.
There is no wifi on the base station that your phone can connect to.
Your phone has to connect to the Internet, usually through the local wifi network from your router.
You then tell the Arlo app on your phone to login to your myarlo account.
Or, if you have a desktop PC, point a browser at this:
Just another user
@VernitaC wrote:
My phone or computer is still not able to access my Arlo Base Station to add my cameras. All lights are green and everything is connected! I just can’t add my devices to my account since the power outage! I need help or maybe need a new camera system?
You have not added any more details in response to the previous suggestion.
Simply repeating the position does not get us any further.
What happens when you aim a browser at:
Can you see your Arlo hub?
Take us through the steps you are using to try to get at your Arlo system.
We know that all lights are green, so you don't need to repeat that. To me this suggests that you hub is working and connected to the Internet.
Just another user
@sobolewskis1 wrote:
I have having the exact problem.
And I have the exact same answers.
Thoughts on what you can do to rescue your system depend on the information that we have.
Vague details of the problems at your end will only elicit vague suggestions.
Just another user
I have having the exact problem. We had electricians working the other day on the house, now cannot connect. Lights are all green but we remain offline.
If you see the base as off-line in your account, then one thing we commonly suggest is to try removing the base from the account, and resetting it (using the pinhole in the back). Then re-add it (along with the cameras).
FWIW I have sometimes had to do this with my one of my bases (which also had a green status).
If the web client doesn't find the base when you try to re-add it, then try contacting support ( https://www.arlo.com/en-us/support/contact.aspx )
