  • 11 Replies
  • 3430 Views
fritzschwindt
base station will not connect to internet.  I have tried factory reset with same result.  How do I get it to go?
11 REPLIES 11
what have you tried already and what service do you have for internet ( and speed if you know )
fritzschwindt
I have cable internet services.  I don't know the speed but it is not dial up speed nor the high speed service.  I have tried two locations for the internet connection - a wireless router I hooked too and a switch right off the modem.  Neither worked.  I have done th efactory reboot on the Arlo statioin and rebboted the internet modem.  Notheing works
brh
@fritzschwindt
Who is your internet provider?
Is your modem also a router?
Who is the Modem's manufacturer and what is the model number?
Are you using a firewall?
The answers to all of these questions are necessary for someone here to be able to help you.
Brian
fritzschwindt
The modem is a Cisco DPC3010.  It is not a router.  I get internet access through my cable company.  They have an open modem with no ports closed.  I do have my firewall turned on.
brh
@fritzschwindt
The Base station needs a router to work. Usually a stand alone modem, which it looks like this is, only has one Ethernet plug to be used by a router. Are you pluging the base station into this plug? You will probably need to need to purchase a router.
Brian
fritzschwindt
I have a wireless linksys ac1750 router and I plugged the internet connect on this device as well and it didn't work there either.  I have a switch after the modem where I plug all my internet devices into and that is where I also tried the Arlo base.  I turned off the fire wall and that did nothing.
brh
@fritzschwindt
Ok, I gotcha. If you have the capabilities to change settings on the router, be sure that ports 80, 123, 443 are open.
What color is the middle LED in the base showing?
Brian
brh
fritzschwindt
The middle light is a solid green light.
brh
@fritzschwindt
I am assuming the third LED on the base is solid amber.
Solid green middle base LED means that the base is connected to the internet, so you don't need to research that problem further.
Can you log into your account on the app? If so go to Settings > My Devices and see if you can see the base. If so go to the Devices screen, Select Add Device, briefly press the sync button on the base then briefly press on the sync button on one camera. The camera light should blink blue slowly at first followed by rapid blue blinking. Don't do anything until the blue blinking has stopped. If the camera is updating firmware it will blink amber then purple for a few minutes. DO NOT REMOVE POWER to the camera or do anything else until this blinking has finished unless it continues for 20 to 30 minutes or turns solid amber which means the firmware update did not take.
Then repeat the sync processs with the other cameras one at a time.
Brian.
brh
@fritzschwindt
I made a mistake in my previous post. Firmware updates will cause the LEDs in the camera to flash alternately blue then amber, not purple.
Brian
