Base Station Has High Pitch Sound/Static Noise
VMB4000 arlo base station is making a high pitch sound/static noise that's consistently on going. I tried to sync the base station but it did not stop the noise. Have anyone else had this problem and what did you do to correct it?
dg429,
Is this a noise in your videos or is this a physical sound coming from the base station?
I think it maybe coming from the base station. I have already reset the base station and sync both camera and I still hear the sound.
dg429,
If the base station is physically making a sound I would suggest contacting customer support regarding this. I have attached the link here for you - Arlo Tech Support
