Authentication failed on S21 Ultra
  • 5 Replies
  • 2214 Views
alexakah
I am trying to log on to Arlo app on my phone Galaxy S21 ultra with Android 15 and UI7.0  It fails with authentication failed message.  I can log on to same account with PC Web browser or another phone (Samsun Note 9) and Android 10 and UI version 2.5 No Problem.  This used to work prior to update of UI and / or App update.  Anyone else have the same issue.  Will there be an update to Arlo app soon?
Have you rebooted the phone and reinstalled the app?
5 REPLIES 5
BrookeN
@alexakah were you able to get into the account?
alexakah
No problem persists. I updated Arlo app still no luck
alexakah
Yes but nothing changes.
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
