OK so I could enable/disable audio detection as required previously, but ever since the new version of the app was released, I can not for the life of me find the setting to disable audio detection.
I can adjust the audio detection sensitivity via settings > audio settings, but there is no option to disable audio detection.
Could someone please assist with this, as I currently have audio detection enabled, making this camera useless for outdoor use due to constantly recording due to wind noise etc.
Thanks in advance.
Like before, this is enabled in the rule for the camera in the modes you are using.
Do you mean settings->default mode settings?
Settings->audio settings lets you set the speaker volume and enable the microphone. But it does not have any setting for audio detection.
