ArlsECOND o Pro
I have a shed which I want to put a camera on but the I loose signal from the base at about 10 metres away. The shed is 30 metres away and I have a Wi-Fi signal in the shed. The base only has to travel through one glass window so the signal reduction isn't that great. Do I need another base unit in the shed?
The only true way to expand the coverage area of Arlo is to add addtional bases...
You will need and eithernet port at the location of the second base by either a direct cable or a wifi extender with an ethernet port
