How can you view recordings one month prior?
Unless you have a service level that keeps the videos for 30 or 60 days, you CAN'T unless you download them.
If you do then it as easy as scrolling back in the Library's calendar
D/L is your friend if there are any videos you think you might even want.
One month prior? If you mean last month, look at the top bar of the library and use the left arrow or the month displayed there to go to that month. Of course, you have to have a plan that allows you to go that far back right now (this is the 14th) since the free plan is only for 7 days.
