Arlo security cameras
  • 1 Reply
  • 1257 Views
jvquirk
We moved and I am not able to sync my Carlo VMB300 base station and security cameras. The base station is
showing 3 green lights, but the app will not sync the cameras for viewing. Has anyone else experienced similar
problems?
Thanks,
Jim
What did you do before the move? All that is normally needed is to turn off and unplug the system (remove batteries fom the cameras since they will wear the batteries down trying to connect to the unplugged base) followed by pl;ugging the base in and installing the batteries. Have you verified the batteries are charged?
