  • 2 Replies
  • 1841 Views
Ish2005
I have the arlo pro and I purchase a Arlo Pro2 camera and the quality looks the same as the Arlo Pro I do not see no 1080p on the Arlo Pro 2 camera can someone help me with this
Have you set the Pro 2 to use Best Quality in Settings, My Devices, your camera, Video Settings?
The difference between 720 and 1080 isn't going to be earth-shattering but should be noticeable. Download a recording or snapshot from your library and check the file properties to see what is captured.
Ish2005
Yes it's on best quality I just noticed the picture quality looks exactly almost the same was going to upgrade my camera but for the price is not worth it when the quality looks the same
