Arlo pro wireless can not add new device to my phone app
Hello
I can not add new device to my phone app also the camera will not syn with the base station.
Both lights are green but the internet one blinks now and again.
any suggestions?
Ryan
What's happening? You press the sync button on the base station and the camera LED should start blinking green. You press the sync button on the camera and the front blue LED should slowly blink until it connects at which point it will blink quickly. If you never see the blue LED blink quickly, it may be due to interference. Make sure the camera is relatively close to the base station. Check for possible wifi intereference eg your 2.4GHz wifi network
How do you know the cameras are connected to the base if you can't see anythinng in your app? We need a lot more details.
Sounds like you sync'd the cameras before you claimed your base station. You may need to a do a factory reset.
Hold the reset button on the back in with a paper clip etc until the power LED goes amber. Wait until it restarts and the power LED goes green and the internet LED goes green. The camera LED will be off.
Then go into the app and Add Device and add the base station
Only then should you go through the camera sync'ing process
I have the same issue here where my app cannot detect the base station.
The LED are all green however I sync'd the cameras before I claimed my base station, is this could affect to detect the base station on the app?
Another important question:
1. In order to discover the base station, do I need to open the port 80 and 443?
2. If the base station power the internet LED in green, does it means that is connected and the ports are open?
3. When I try to test my port 80 or 443 on doyouseeme.org, it says like "connection refused". I currently have a Huawei HG8245 provided by Claro.
It does help to follow the directions, claiming the base before syncing the cameras. Hold the reset button until the LEDs flash amber and then claim the base. THEN sync the cameras.
My base station won't reset, the lights stay green. The only time they turn Amber is when I turn the base station off and back on. There doesn't seem to be much support from Arlo on all these issues what people seem to have.
Do they have a contact number??
It can take up to 10 seconds of holding the reset button in before the power LED changes from green to amber
For support, go to the bottom of the page here and click "Contact Support"
