One camera will not respond ro set up for no notification. Still get text everytime there's motion. Called Arlo and they said they could fix problem for $139.95.
All other cameras work perfectly , as well as this one. the only thing is I keep getting the text messages that there's motion.
Must be a simple fix. What is it?
I think you called someone other than Arlo/Netgear. Make sure you use the Contact Support link at the bottom of these pages, not from a web search.
Have you checked your modes? If so, have you made sure to save at each step where its available as you back out?
