Camera takes a very long time to turn in for live view
6 REPLIES 6
Hi @Ematt1996
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Hi, I tried turning the camera off and re installing camera.
Hi @Ematt1996
Does this occur on the web browser & Arlo app? If only the app, I would suggest to try & remove > Re-install the app and test again.
Ok thanks. I will try that tomorrow. Working now. I will keep u posted. Thanks again.
Sorry for the late reply. It’s still doing the same thing.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
