  • 1579 Views
Travismiller23
I have an Arlo pro outside camera hooked up. It is attached to a couple modes I have created. For some reason it just starts recording without any rules triggering. I ah e adjust the sensitivity settings all the way down for just take camera. It continues to record for no reason. Anyone experiencing something similar that might have some advice for me?  Appreciate the help.
DannyBearAgain
Can you supply more detail of the setup? What camera/base model etc.
start with power cycling the base then reset the cameras. Pull battery for 10sec.
Travismiller23
Thank you for the response. It is a first gen Arlo pro camera. My base station is older as well. It is VMB3010r2.
DannyBearAgain
Where are you adjusting the camera motion sensitivity?
To adjust the motion sensor go into the mode’s camera rules, the adjustment in the camera settings is just for testing.
Also confirm that you are not getting wind setting off the sound detection.
