Arlo pro out side and inside cameras
So my outside camera is very delayed I can not figure out the reason for this. Would anyone know why this is happening? Also my wifi is strong so that's not the problem.
It's not your wifi that matters...each base sets up its own network that talks to the cameras only, so it's the base signal strength that matters
Antj,
Do you see the same behavior if you bring the camera close to the base station? It could be, as TomMac suggests, an issue with the signal strength between the base station and the camera.
