My current Arlo Pro is attached to the permanent Arlo outdoor mount (VMA1000)
My question now is the Arlo permanent mounting attachment to the Camera unit is very close to the rear camera unit power port.
Will the new outdoor cable power (VMA4700) supply attachment will easily connect to the Arlo Pro rear power connector without issue if the camera is attached to the Arlo permanent mounting bracket?
OK I get it.
I just did this test for you. It's tight but it does work.
6 REPLIES 6
It will depend on the angle of the camera in relation to the mount.
Having said this, the connector on the outdoor power supply is at 90 degrees to the cable so you should be able to insert the usb connector first and then angle your camera accordingly.
Ok. Thanks for the response! I'll check Bestbuy tomorrow and pick up one.
I forgot to mention, it's that big knob you tighten on the permanent outdoor mount that is very close to the rear power port of the Arlo camera. The camer position or angle is not an issue.
Retired_Member
Not applicable
2017-08-26
01:50 PM
W
OK I get it.
Thank you very much for test fitting it.
This really answered my question.
I'll buy one tomorrow then.
