Arlo pro motion detection problem
after detection the camera is recording and if there is a second movement you dont get a alert.
When you go to the the app you see that the orange dot with the 3 stripes is recording and is orange.
anybody if any idea?
If I get what you are asking, the secondary motion will not alert when the camera is already recording... when the cam stops recording it will send an alert upon a secondary motion detect ( with the reset time of about 5-10 secs )
The "dot and stripes " is that motion detect icon
gray is off, black is armed, amber is recording
