Arlo pro, low video quality
II feel the video quality should be better. I do have it set to best, but still getting pixelated images. My upload speeds are around 6meg.
what am I missing?
Set the video settings to Best Video for quality.
Ensure you have full signal strength for the camera. Minimise the distance and objects between your camera and your base. Often this will be moving the base station to the most central point in the house in relation to the cameras. If you don't have ethernet there, consider a range extender with an ethernet port to plug the base into or something like a powerline kit.
Ensure you have the latest firmware for your cameras. If they're not updating automatically, power cycling the base station can help
