Arlo pro external memory
  • 7 Replies
  • 4888 Views
Mga_arlo
Hi everyone,
I have a 300mg external memory device on my arlo pro base station. Does anyone know how to use the external memory and save clips onto the external memory?
7 REPLIES 7
Streak2
Master Master
Go to settings. Click on your base and enable local storage.
Mga_arlo
Thanks I understand how to connect format and find the device in settings. I want to know how to add clips manually into the external device
Streak2
Master Master
Recordings are automatically stored to the external device and to the cloud.
Under what circumstances would you want to manually save clips to this device?
Mga_arlo
Sweet thx! I'm assuming once memory runs out the oldest files will be overwritten?
Streak2
Master Master
There's an automatic overwrite box that you can select or not as you wish.
Mga_arlo
What happens if u don't select the automatic overwrite box?
Streak2
Master Master
Stops recording when it's full.
