I have the same problem with a camera of ours. I have removed it, added it, turned the motion up and down, turned it to off then back to on, charged it, switched batteries, and cleaned the lens, all to no avail. We have 3 cams to cover one view just to see the ongoing motion, especially with the delay in recording start we now have system wide.
Hi @Wolfy13
Did you adjust the viewing angle or sensitivity by chance? Have you tried adjusting the sensitivity to pick motion further away?
I'm having the same issue right now with my Front door camera. all my other cams record and detect. I verified the front door cam does indeed detect motion by doing the motion detect test. Not sure.... still working on it. I just removed and readded the cam. lets see if that works
it worked. Try doing that. removed the device and re-sync it to the base unit
Same problem as I have and it occurs in the meantime every 2 or 3 days and I have more than 10 cams; only solution is hardware reset base station and to add each cam again; it takes me always hours .... Arlo Support simply does not take care for their bad software!!!
