Arlo pro charger... do I have to use the arlo pro cord and charger or can I just use cord and get another charger
widget1,
You must use the 9V Arlo Pro power adapter and power adapter cable that came with your Arlo Pro system to charge your Arlo Pro. A regular 5V Micro USB cable does not have high enough voltage to fully charge your Arlo Pro Wire-Free camera.
What power adapter can I use to charge my Arlo Pro or Arlo Go batteries?
widget1,
the Iphone adapter has enough current for the camera and it will run fine......
BUT, What I would do is pull the battery for safety
