Arlo pro charger help
A separate battery and charger is available:
https://www.amazon.com/dp/B01LYCMLY5?tag=price2289-20&ascsubtag=244510239&m=ATVPDKIKX0DER
Any Qualcomm Quick Charge capable charger should work. The cable may be an issue since it has to fit in the camera securely but some trimming of the plastic surround on the cable's connector should make it fit.
I also need an indoor charger cable for my arlo pro. I've purchased a cable from Amazon which claims to work but when I plugged it in the app says it won't charge with that cable.
Arlo: it doesn't seem reasonable to not be able to purchase an addiontal charging cable.
It's likely not the cable although that is a possibility. To charge the Pro battery requires a charger that conforms to the Qualcomm Quick Charge capability with 5v and 9v of at least 1.5 amps. Many new phones use this so buy such a charger compatible with something like the Samsung S7/8. Check the specs first, though.
Ok. I misunderstood. I will try one of the wall chargers that you linked to earlier.
Thank you,
Andrew
