Arlo pro cannot be viewed with MacBook Pro
Hi,
I logged into my Arlo account on my MacBook Pro and viewed the videos in my library. However, when I try to view the Live cameras, I get a message that I need Adobe Flash Player to view it. Apple does not recommend Flash Player on their products due to problems. My husband has an IPad Pro and views the Live camera feeds without any problems. He does not have Flash Player either. Why can't I view the Live feeds on my MacBook?
Laura
AFAIK, the apps don't need flash. iPad Pro still runs iOS and apps from the app store so works the same as a smartphone.
For a browser on a computer, you'll need flash
If you really want to use the computer, install Chrome and use that for Arlo.
