Arlo pro, can't add a 4th camera
  • 1 Reply
  • 3896 Views
francescoo
I bought Arlo Pro with 4 cameras.
I correctly sync 3 cameras but I can't sync the 4th camera.
When I start the sync process the 4th camera led blink in amber; I already try to charge the battery, remove the battery but I was not able to sync this camera.
The camera is brand new and never been used.
What can I do ?
First, make sure you're only briefly pressing the base sync button - don't hold it.
Remove the battery and use only the power cord.  Try syncing- did that help?  If not, you have a bad camera.  Swap the system at the store or open a case with support using the Contact Support link at the bottom here.
