Arlo pro cameras record on there own
  • 2 Replies
  • 2909 Views
Qbanlink
I perchased 8 arlo or cameras and I'm having an issue with 3 of them. The issue only happens at night and when the system is armed. What happens is when the system is armed at night and want to view the camera live it starts to record by itself there's no motion no sound to activate the cameras and it only happens with 3 of my cameras. Does anyone know how to fix this
Qbanlink
Arlo pro
First take one of the cameras causing problems and open/remove the battery and then replace... this will reset the camera.
Then take the same one and swap it with one NOT causing problems to see if it is the camera or location ( see if problem follows camera )
NEXT if still NG, go to settings and use REMOVE DEVICE for that same camera and bring it back as new ( this will reset the defaults of the camera )
test again...
If the problem continues, contact Netgear
