  • 8 Replies
  • 3349 Views
gregorywalstrom
Unit is starting to record when vehicles pass on the street. Street is about 90 and 100 ft respectively from cameras
8 REPLIES 8
Streak2
Master Master
Have you tried reducing sensitivity under the Mode tab?
Or turn off the audio trigger in your modes.
gregorywalstrom
Audio is off. Just turned sensitivity down to 70. We'll see.
gregorywalstrom
I just turned the sensitivity down to 70 in the motion detection test.
gregorywalstrom
Well, the 70% didn't work. 2 cars going down the street triggered them.
gregorywalstrom
Here is a detection for 6 seconds. Nothing out there. What sensitivity should I use. I did 70% on the motion sensitivity test. Couldn't upload it, wrong type of file. What will happen if I continue to turn down the sensitivity?
Streak2
Master Master
The motion detection will become less sensitive.
Keep going down in steps of 5% until to does not trigger to your satisfaction then bump it up 1% at a time to find your sweet spot.
gregorywalstrom
I'll try that, thanks
