Arlo pro base offline
  • 1 Reply
  • 3208 Views
Sstrain
Recently my arlo base station is offline. My three LED lights show green amber then green.. going back n forth between all green to those colors listed above.. i have done reset of my arlo devices. i have no internet problems, but for three days now my base is offline.. did nothing different.. need help figuring this out because nothing on this forum helps my situation..
Sstrain,
The amber center LED indicates the base station is connected to your router, but doesn't have an internet connection. Try power cycling your base station and your router, allow the router and base to come back online and test see if you still experience the same issue.
