Arlo pro alarm
  • 1 Reply
  • 3110 Views
Abianco
How can I activate the alarm mode when I have 2 cameras outside an 2 inside and I would like to activate only the inside ones?
You will need to creat a cutom MODE where the inside cams have the alarm off OR you can just arm the outside cams
( split them to inside/outside )
read;
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-modes-and-rules-and-how-does-Arlo-use-...
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-for-my-Arlo-Wire-Free-ca...
