Arlo pro add-on camera from USA compatible with UK system?
  • 2755 Views
  • 2 Likes
Efc1888
Afternoon - tried searching everywhere but given up. If I purchase an add on camera from Amazon USA and get it shipped to the UK will it be compatible with the UK system? Same batteries and chargers or would I need USA bought charger for that one camera?
Many thanks
The cameras don't care as long as you use an Arlo charger or at least a quality charger that supports Qualcomm QuickCharge capability (5v and 9v). The cameras and batteries are all the same.
brh
@Efc1888
To the best of my knowledge they are compatible. The supplied charger with the Pro models work with either 110V and 220V. All you will need is a compatible ac wall plug or travel adapter.
Brian
Efc1888
Thanks both
