Any suggestions/advice for new users ? Thanks. R
Read the manual
Read the FAQs
Familiarise yourself with how everything works.
Position your cameras well and adjust the motion sensitivity ot suit the area
Consider 2 cameras at right angles for important areas like your front door and have both cameras record and also trigger each other
Consider a UPS for the base in case of power cut and attaching a USB drive
Consider scheduling modes to suit certain times of the day and/or Geofencing for different modes when you're home or away from home
If on android, turn off app optimisation for the arlo app. If iOS, turn on background refresh
Read the manual
Read the FAQs
Yes, Read the FAQs
