  • 2 Replies
  • 3127 Views
Royce54s
Any suggestions/advice for new users ? Thanks. R
steve_t
Master Master
Read the manual
Read the FAQs
Familiarise yourself with how everything works.
Position your cameras well and adjust the motion sensitivity ot suit the area
Consider 2 cameras at right angles for important areas like your front door and have both cameras record and also trigger each other
Consider a UPS for the base in case of power cut and attaching a USB drive
Consider scheduling modes to suit certain times of the day and/or Geofencing for different modes when you're home or away from home
If on android, turn off app optimisation for the arlo app. If iOS, turn on background refresh
steve_t
Master Master
Read the manual
Read the FAQs
Yes,   Read the FAQs
