Arlo pro 1 camera loosing charge at double the rate of other batteries
Arlo system with 6 cameras - 1 camera loosing charge at double the rate of other batteries. It does not work harder than others. Is it a dud battery. Is there a warrany on this.
Could be. Try changing the battery into one of the other cameras. If that doesn't confirm a battery problem, try changing the draining camera to a different position - swap it with one of the others - to see if it's a camera problem
