  • 1 Reply
  • 7136 Views
Uriko
Hi!
Plan to put Arlo in the car.
Have two questions:
1) can the Arlo Base Station to stand in the car in cold weather and if so, what temperature will be able to withstand ( I'm in Canada!);
2) a set of Arlo advise (which camera to choose and what accessories)?
Uriko wrote:
Hi!
Have two questions:
If you put an Arlo base in a car and run Arlo or Arlo Pro cameras, it WILL NOT WORK !
First the base unit requires an ethernet port to function ( which is possible with a hotspot cellular unti that has an ethernet port , but not likely )
Second, the arlo and arlo Pro do not detect motion thru glass...you wil not get any recordings.
If you need a camera that will work in a car, you have only the Q camera as a choice... which will detect thru glass ...but you have to hook it to your home wifi ( if it reaches ) or as above, a wifi hotspot with cellular that it can connect to.
