Arlo cameras - not staying connected to base station
HW VersionH7
Serial Number48B45A7Y04546
Firmware1.2.11810
After the firmware update this is my error.
This Arlo device is offline
If I turn the base station off it works sometimes. If that doesn't I have to remove batteries for a few minutes. It only stays online for a limited amount of time. I need help resolving this issue. Dennis
Try resetting the system by removing all devices in Settings, My Devices. Start fresh. If it still happens, open a case with support using the Contact Support link at the bottom here.
