Arlo camera is dead. Received a charging fault, now it won't stay on. Model VMC4030
I purchased my 4 camera Arlo Pro (VMC 4030) at the end of November 2017. I spent a lot of money on this system. I have been very disappointed with it. I was already sent 2 refurbished batteries to replace the defective ones. My biggest letdown came this past weekend. I noticed I received a charging fault on my indoor camera. I unplugged it as it is always powered via AC power. Looked inside the battery compartment and didn't see anything. I tried fresh batteries and nothing. The blue light stays on for a sec or two and then nothing with both AC or battery power. Not good for an indoor camera after not even a year and half of use. Tried to reset the base station and that did not help either. I'm so disgusted and frustrated. I was hoping to buy the new Arlo Ultra system but after this weekend I don't think that's gonna happen. If there is anything different I can do I would appreciate any suggestions. Thanks.
Hi @Bosox4
Does the camera boot all the way up to where you can access it via the app or web portal, or is it inoperable?
Is that AC cable the original one that came with your camera? Does the battery & AC cable that did not work with the issue camera work with your other cameras?
Have you tried contacting customer support regarding this issue? Support may have some techniques to help the camera come online. I have attached the link here for you - Arlo Tech Support
Hi @Bosox4
I will reach out to you in a private message to further investigate this topic.
