  • 4 Replies
  • 3271 Views
Axis0mx
Solid green light on base but camera on solid Amber. Tried yo conect in new home network with no success. Tried reseting router and base with no luck. App says base is offline.
steve_t
Master Master
Generally the camera LED being amber means you haven't claimed your base station. You should remove your cameras from your account and then add the base station and then sync the cameras
brh
@Axis0mx
You are going to have to provide us with a little more information if you want us to try to help you.
Is the solid amber light on the base station or the camera?
If it is on the base station, which light is amber? Starting from left to right tell us which light is amber.
Pages 52 and 53 of your manual gives you some troubleshooting tips if the nternet light on the base is solid amber.
It is possible that your router has ports 80 or 443 blocked. If you can check these ports statuses, great, if not, contact your router manufacturer to see how to check that.
Brian
steve_t
Master Master
sabrina_7972
My arlo base is solid green on power, connection is blinking every few minutes and then the camera is solid orange. I have reset it twice already, unplugged and plugged back on. Checked my internet and they are all good. When i open my app on my phone it's saying " Arlo app says says Your Arlo device appears offline". I'm out of solutions. Could it be the netgear is offline since yesterday in our area? I don't have the connection for two days now. Can you please help? Thank you.
brh
@sabrina_7972
The amber camera light means you have not "claimed" your base station after the reset. The reset removes the base from your system.
From the Device section of your app, add the base back in and if necessary resync your cameras one at a time.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
Brian
