Good day,
I would like to know if the Wall Mounts model VMA 1300 will work well with the Arlo Pro cameras in an outdoor rainy region? What are the pros and cons of these wall mounts?
Best regards,
Ben in Vancouver
If your talking the half ball silver mounts , yes... the Pro should be fine on them. I have one mounted for a year now.
There was a short term issue where the pros would slide a bit but that issue was fixed at the manfufactors side a while ago.
Thanks for the quick answer. I was afraid the camera could get knocked off by the wind or perhaps a bird?
